Out of Office
broaton
Platinum Partner
I really wish we could get the dial codes for in/out of Office again.
I understand trying to have different operating hours for different groups, but if it could be applied to global hours that would solve a lot in my customers world.
Pushing a button on the phone is much easier than login in everyday.
Reactions: RCCradio
This is already available in V20 with the Call Processing Script as explained in the guideline here.
Think of it from the perspective of a Multi tenant instance. Someone putting one company into out of office would put other tenants as well. Imagine someone else defining your office hours.
Reactions: fxbastler
I understand that, how do you explain that to a single tenant user?
It use to work now it does not, they don't like it.
For the 3CX Hosted installations this is a restriction which as per announcement here it will be removed in the next Update4.
Are you're saying in update 4 we can use the script to enable office hours by dial codes using the hosted version?
These are really fantastic programs and examples.
With just a little bit of knowledge someone can extend them:
- query the calling extension
- determine if they are allowed to make such a change or ask for a PIN; if so, then
- determine the primary group of the extension or ask for the group to be changed
- switch only this group
just an idea ...
Ok, all i care about right now is day and night modes.
On the current hosted by 3cx version, can we use dial codes to change it.
A simple yes or no question please.
Correct, this will be available in Update4.
tom.walker@blackcountryra
