Solved outbound caller id not working anymore
GVB
For some reason the outbound caller IDs are not working anymore.
The only changes I can remember are:
entering a phone number in the Default caller ID field of the trunk.
creating some groups for the pickups
add these groups to the default outbound rule
How should I troubleshoot this?
The activity log doesn't seem to show the outbound id? or is this log not capturing this?
Code:
01/29/2019 7:35:09 PM - [CM505003]: Provider:[telenet] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:[email protected]:5060]
01/29/2019 7:35:09 PM - [CM503002]: Call(C:1): Alerting Line:10000>>myCellPhoneNumber by contact <sip:[email protected]:5060>
01/29/2019 7:35:09 PM - [CM503025]: Call(C:1): Calling T:Line:10000>>myCellPhoneNumber@[Dev:sip:[email protected]:5060] for L:1.1[Extn:917]
01/29/2019 7:35:08 PM - [CM503027]: Call(C:1): From: Extn:917 ("myExtentionName" <sip:[email protected]:5060>)  to  T:Line:10000>>myCellPhoneNumber@[Dev:sip:[email protected]:5060]
01/29/2019 7:35:08 PM - [CM503004]: Call(C:1): Route 5: from L:1.1[Extn:917] to T:Line:10000>>myCellPhoneNumber@[Dev:sip:[email protected]:5060]
01/29/2019 7:35:08 PM - Line limit check: Current # of calls for line Lc:10000(@telenet[<sip:[email protected]:5060>]) is 0; limit is 20
01/29/2019 7:35:08 PM - [CM503004]: Call(C:1): Route 4: from L:1.1[Extn:917] to T:Line:10000>>myCellPhoneNumber@[Dev:sip:[email protected]:5060]
01/29/2019 7:35:08 PM - [CM503004]: Call(C:1): Route 3: from L:1.1[Extn:917] to T:Line:10000>>myCellPhoneNumber@[Dev:sip:[email protected]:5060]
01/29/2019 7:35:08 PM - [CM503004]: Call(C:1): Route 2: from L:1.1[Extn:917] to T:Line:10000>>myCellPhoneNumber@[Dev:sip:[email protected]:5060]
01/29/2019 7:35:08 PM - [CM503004]: Call(C:1): Route 1: from L:1.1[Extn:917] to T:Line:10000>>myCellPhoneNumber@[Dev:sip:[email protected]:5060]
01/29/2019 7:35:08 PM - Call(C:1): Call from Extn:917 to myCellPhoneNumber matches outbound rule 'Default Outgoing'
01/29/2019 7:35:08 PM - [Flow] Call(C:1): has built target endpoint: Out#:>>Rule{Default Outgoing}>>myCellPhoneNumber for call from L:1.1[Extn:917]
01/29/2019 7:35:08 PM - [Flow] Target endpoint for myCellPhoneNumber is Out#:>>Rule{Default Outgoing}>>myCellPhoneNumber
01/29/2019 7:35:08 PM - [CM503010]: Call(C:1): Making route(s) from Extn:917 to <sip:[email protected]:5060>
01/29/2019 7:35:08 PM - [CM505001]: Endpoint Extn:917: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Fanvil X3S 2.8.0.6251 0c383e1ca04e] PBX contact: [sip:[email protected]:5060]
01/29/2019 7:35:08 PM - [CM500002]: Call(C:1): Info on incoming INVITE from Extn:917:
Invite-IN Recv Req INVITE from 192.168.0.168:5060 tid=20987804235596431 [email protected]:
INVITE sip:[email protected]:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.0.168:5060;branch=z9hG4bK20987804235596431
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: "myCellPhoneNumber" <sip:[email protected]:5060;user=phone>
From: "myExtentionName"<sip:[email protected]:5060>;tag=153479820
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REFER, NOTIFY, INFO, PRACK, UPDATE, MESSAGE
Content-Type: application/sdp
Proxy-Authorization: Digest username="ChbIgr3stB",realm="3CXPhoneSystem",nonce="414d535c12612ddc21:64b5f0afab99c7639061131117a59b14",uri="sip:[email protected]:5060;user=phone",response="1e513e89f21598d52bd0f299c5b9ba62",algorithm=MD5
Supported: replaces, join, path
User-Agent: Fanvil X3S 2.8.0.6251 0c383e1ca04e
Allow-Events: talk, hold
P-Early-Media: supported
MAC: 0c383e1ca04e
Content-Length: 392
v=0
o=sdp_admin 1101019587 188342392 IN IP4 192.168.0.168
s=A conversation
c=IN IP4 192.168.0.168
t=0 0
m=audio 10048 RTP/AVP 0 8 9 18 4 2 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:4 G723/8000
a=fmtp:4 bitrate=6.3
a=rtpmap:2 G726-32/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
That might have something to do with it.
Do you mean that the outbound caller ID, set against each extension, is no longer working? Does the number set against the trunk show instead? Do you have the outbound trunk settings to take the number from the extension?
Yes, my guess is that it happend after entering the main number in that caller ID field.
No matter which phone I use to dial out it always show the same number.
I'm not sure if it changes when I change that value.
I don't know about that last question you're asking. If you mean those 2 "take outbind id from manager settings" then those are still set like before.
If I change the "Configure Outbound Caller ID" number it still shows the number that you see in "main trunk number"
Edit: I can change that main trunk number but it still shows up as the other number.
ok, I think I figured out what goes wrong...
we gave 4 or 5 10-block number ranges.
only 2 of them have been ported to SIP so far and it seems that the provider only allows CIDs from those 20 only.
it works fine on the phones I did at the start but not the newer ones which are currently forwarded from the original Alcatel pbx to the 3CX one on a different number.
so it will only work when all those blocks have been added to that sip router/gateway thing.
Some providers are like that. To prevent spoofing. they will only allow caller ID for numbers that you have, on record, as actually being yours, which means ...ones you have bought from, or ported to them.
Glad to see the issue has been resolved. For future reference and assuming the trunk is set up correctly to show the Outbound caller ID taken from extension settings then the outbound caller ID is selected with the following order:
  1. Outbound caller ID set under extension settings
  2. Caller ID set in trunk settings
  3. Main trunk number.
Rich Hopkins
