- Joined
- Dec 12, 2023
- Messages
- 12
- Reaction score
- 1
I'm unsure if this question has been asked before, but is it possible to put a rule in place, so that if someone on the 3CX PBX calls another person on the same PBX but dials out using their DID it matches a rule and sends it internally to that person, instead of incurring costs going via the SIP trunk?
Something like a rule that matches +44128300000[0-5] to 10X or something that allows you to put manual pattern match in if there's no correlation in the DID to internal extensions?
Currently it would seem that the only outgoing rules are either to block, or send via trunk, nothing to send the calls back inside if it matches a number on the same system.
Rob
Rob
