Outbound routes, can't work with soft phone?
ericmachine
Hi everyone,
I got my outbound routes working for Yealink SIP-T28P.
From the IP Phone, I could call these numbers:-
- any extensions (for sure)
- 032XXXXXX (local number)
- 01XXXXXXXX (mobile number)
It works!
But on the soft phone side, I can't make it work.
I tried to call this:-
- [email protected] (local number and suffix the elastix server IP)
- 01XXXXXXXX (mobile number and suffix the elastix server IP)
None works.
Got this error "Your call can't be completed as dialed. Please check the number and dial again" and can hear the tootuutoo, something like that.
My dial patterns as follows:-
prepend | prefix | match pattern | caller id
nothing | nothing | 01XXXXXXXX | nothing
nothing | nothing | NXXXXXXX | nothing
Any tips from the forum? Thanks.
Ericmachine,
Can only take guesses here...could be many things...
Dialplan in the Softphone....(remove the dialplan altogether)
1) make a call with your T28 to the number
2) Make a call with your Softphone to the same number
Check the /var/log/asterisk/full
Check to see what is in the log for those calls
Post the logs here (separated) so that we can see what is happening
Regards
Bob
by the way, bria3 original works fine but not x-lite, probably free has limitations :)
ericmachine,
xlite should work....main thing is that Xlite has no g729 codec. Your T28 phone has the G729 codec. Bria has the g729 codec.....
So if you have setup to use G729, this may explain it....
Regards
Bob
Noted and thanks, but I can't seem to find a way to add the G729 codec to X-Lite? Can that really be done?
With Xlite ....no...
You need to purchase their commercial products for G729 (e.g. Bria etc). G729 is a licenced product and they pay a licence fee for its implementation in a product.
Products that you have bought such as Yealink T28, have it included.
This is why all free softphones do not come with G729.
In a normal LAN environment, there is no requirement for G729, use GSM or Ulaw/Alaw
Regards
Bob
Noted and thanks :)
iamatlas
