Outbound Rules
Wael
Hello, I'm trying to configure outbound rules however whenever I try to call I get an error voice message (Destination is not available, not registered, or there is no routes available.)
Country code: 00961
Country: Lebanon
Numbers Sample: 70 XXX XXX / 76 XXX XXX / 03 XXX XXX
Trunks: DBL Goip
However I have no issues with inbound calls.
What do the activity logs say?
Reactions: ChrisC_3CX
I'd too recommend checking the activity log as this may be happening due to a specific SIP response from the SIP Provider. First, enable Verbose Logging under Dashboard >> Activity Log >> Settings, then replicate the issue again by attempting an outbound call and then go to Dashboard >> Activity Log >> Filter, select the last call and then check the responses.
Alternatively, as a quick test, you could navigate to Settings >> General and disable " Play Busy prompt when extension is busy" so that you hopefully get the error on your 3CX Client instead of an audio prompt.
jmarshall
