Solved Outgoing calls failure - 403 Forbidden failed
JoelFSG
Good morning,
I am in the process of setting up a 3cx phone system.
We have completed the basic configuration and obtained a temporary number range to test from our new SIP provider.
Now all the incoming rules we setup to forward to extensions seem to work fine.
However..
Outgoing calls are not working at all. I have recreated the Trunk and rules to no avail.
The error I am getting is below:
12/11/2020 11:16:30 - Call to T:Line:10000>>07790037XXX@[Dev:sip:[email protected]:5060] from L:16.1[Extn:3047] failed, cause: Cause: 403 Forbidden-Source Endpoint Lookup Failed/INVITE from 172.24.211.68:5060
12/11/2020 11:16:30 - [CM503003]: Call(C:16): Call to <sip:07790037XXX@172.24.211.68:0> has failed; Cause: 403 Forbidden-Source Endpoint Lookup Failed/INVITE from 172.24.211.68:5060
The 172.24.211.68 address is that provided by our SIP provider. Can anyone shed any light on why this may error from the above?
Please note the XXX is just masking on a phone number.
  • 3CX Version, e.g. Standard Annual 16.0.6.655 Professional
  • Server OS, e.g. Windows Server 2016 Standard
  • Is the 3CX Server Hosted and where? Onsite hosting
  • IP Phone Make/Model/Firmware - using Client
  • Provisioning Method: Local
  • Trunk Provider or Gateway Make/Model - BT Trunk provider - BT WSIPT
  • Are custom Phone Templates being used: YES
Cheers
Are you using the '3CX BT Wsipt' sip template ?
This has just been resolved. Apparently our provider has the MPLS gateway inside the network so they were not expecting the calls to go out over the internet hence the forbidden message.
We unticked this box under the Sip trunk settings.
"Put Public IP in SIP via header"
Calls are now working.
Thanks for the help
Glad to hear Joel
EMMEPICASA
