OVH Public Cloud option has gone
axium
Platinum Partner
From the 3CX partner portal it is no longer possible to deploy a 3CX instance in the OVH Public Cloud.
Will this option be available again?
we have many instances on that provider and migrating them would be a real hassle, plus the prices on the now available providers are quite a bit higher.
Please find the options for self-hosted instances and how to deploy them here.
However, we do recommend hosting with 3cx: https://www.3cx.com/ordering/pricing/hosted-info/
That doesn't answer the question Charles. Why have you removed the abillity to use PBX express?
We solely use OVH and made the move to Public Cloud with them when you removed the abillity to install from command line. Now you are wanting us to download the iso and install it manually?
Can you not just let us download and install from command line again?
It looks like there are marketplace images for 3cx coming to OVH and Vultr.
See https://www.3cx.com/blog/releases/hosting/ under Self Hosting wizard replaced by Marketplace
I want/need the OVH option too.
Regards
Keith
mazet
