Solved PA Calls Disconnect After 2 Minutes - 3CX with 2N PA Speakers Issue
big.LITTLE
Hello everyone,
I'm encountering an issue with my PA system setup where calls are consistently disconnecting after exactly 2 minutes. I'm using 2N PA speakers integrated with the 3CX system. I'm unsure if this problem is related to the 2N PA speakers or a setting within the 3CX system itself.
Has anyone experienced a similar issue or have any insights on whether this is a configuration aspect within 3CX or a compatibility matter with the 2N speakers? Any guidance or troubleshooting tips would be greatly appreciated.
3CX Version 20.0 Update 0 (Build 1620 Release)
License Type: Professional Annual (4 Simultaneous Calls)
License Key: BDF7-XXXX-XXXX-XXXX
Thank you in advance for your help!
Put system in verbose mode, replicate issue, and check where the goodbye came from. Then you will know which side is stopping the call, but I can almost guarantee you it's on the 2N side.
I agree with @SweetAction. 3CX does not know or care that you are talking to a paging system. Talk to your 2N support.
Reactions: big.LITTLE
Hello @SweetAction & @VoIPTools,
Thank you for your insights on the PA calls disconnecting after 2 minutes. Your advice helped identify the issue with the 2N PA speakers, not the 3CX system. I've contacted 2N for further support. Appreciate the help from this knowledgeable community!
Cheers!
cur_cb
