Solved PA3 and paging
Icedmelan
Forum User
I just installed a PA3 to do paging on intercoms in my company. the goal is to make a post # on my phones and that the message is broadcast on the intercoms. Fanvil tells me it's 3cx compatible and yet I can't assign it a position. can you help me?
That's what I thought but it still doesn't work :(
The Fanvil PA3 is not a supported model currently.
Fanvil provided us with a template for the pa3 but the configuration does not work as it should
I have the PA3 working if anyone needs help.
The PA3 has already been added to 3CX - update your system and you should be able to use it normally
Diogo Maia
