Paging externally and through phones at the same time
paulcaudill
Platinum Partner
I have a client that we are currently using a Patton FXO hooked to his paging equipment. This works great but he would like to be able to dial a code that would page out to his paging system and through the phones at the same time. I hope this makes sense
I have been racking my brain to figure out a way of doing this. Has anyone ever done this?
I have not done it with an FXS i usually just use a sip paging adapter, Snom spa1, but i will set this up later and test. im not sure how the system uses an fxS for paging. Should be as simple as making a page group and adding all extensions to it as well as the extension of the FXS.
The Patton we are using is the SN4114
Here is the config that we use
Code:
# For Patton 2 to 8 FXO
# Supported firmware versions R6.x
# Author: Tommaso Missoni
# Contact: [email protected]
webserver port 80 language en
system
  ic voice 0
    low-bitrate-codec g729
sntp-client
sntp-client server primary xxx.xxx.xxx.xxx
profile ppp default
profile call-progress-tone defaultDialtone
  flush-play-list
  play 1 1000 350 -13 440 -13
profile call-progress-tone defaultAlertingtone
  flush-play-list
  play 1 1000 440 -19 480 -19
  pause 2 3000
profile call-progress-tone defaultBusytone
  flush-play-list
  play 1 500 480 -24 620 -24
  pause 2 500
profile call-progress-tone defaultReleasetone
  flush-play-list
  play 1 250 480 -24 620 -24
  pause 2 250
profile call-progress-tone defaultCongestiontone
  flush-play-list
  pause 2 250
profile tone-set default
profile voip default
  codec 1 g711ulaw64k rx-length 20 tx-length 20 silence-suppression
  codec 2 g711alaw64k rx-length 20 tx-length 20 silence-suppression
  codec 3 g729 rx-length 20 tx-length 20 silence-suppression
  fax transmission 1 relay t38-udp
profile pstn default
  echo-canceler-hybrid-loss 0
  echo-canceler-nlp silence
profile sip default
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_WAN
    ipaddress dhcp
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
  interface IF_IP_LAN
    ipaddress xxx.xxx.xxx.xxx 255.255.255.0
context ip router
  route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.x 0
context cs switch
 routing-table called-e164 RT_SIP_TO_FXO
    route .% dest-service HG_TO_FXO
  routing-table called-e164 RT_FXO_00_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_00
  routing-table called-e164 RT_FXO_01_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_01
  routing-table called-e164 RT_FXO_02_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_02
  routing-table called-e164 RT_FXO_03_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_03
 mapping-table called-e164 to called-e164 MT_CALL_ID_00
    map .% to 000000
  mapping-table called-e164 to called-e164 MT_CALL_ID_01
    map .% to 000001
  mapping-table called-e164 to called-e164 MT_CALL_ID_02
    map .% to 000002
  mapping-table called-e164 to called-e164 MT_CALL_ID_03
    map .% to 000003
 service hunt-group HG_TO_FXO
            drop-cause destination-out-of-order
            drop-cause user-busy
            drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
                        route call 1 dest-interface IF_FXO_0
  interface sip IF_SIP
    bind context sip-gateway GW_SIP
    early-disconnect
    route call dest-table RT_SIP_TO_FXO
            remote 10.1.104.17 5060
            trust remote
    address-translation outgoing-call request-uri user-part fix 10002 host-part to-header target-param none
    address-translation incoming-call called-e164 request-uri
  interface fxo IF_FXO_0
    route call dest-table RT_FXO_00_TO_SIP
    loop-break-duration min 300 max 1200
    caller-id format bell
    ring-number on-caller-id
    mute-dialing
    disconnect-signal loop-break
    disconnect-signal busy-tone
    dial-after timeout 1
  interface fxo IF_FXO_1
    route call dest-table RT_FXO_01_TO_SIP
    mute-dialing
  interface fxo IF_FXO_2
    route call dest-table RT_FXO_02_TO_SIP
    mute-dialing
  interface fxo IF_FXO_3
route call dest-table RT_FXO_03_TO_SIP
    mute-dialing
context cs switch
  no shutdown
authentication-service AS_ALL_LINES
  realm 1 3CXPhoneSystem
  username 10002 password hkjhduiud
location-service LS_10002
  domain 1 xxx.xxx.xxx.xxx
  identity-group default
    authentication outbound
      authenticate 1 authentication-service AS_ALL_LINES username 10002
  identity 10002
    registration outbound
      registrar xxx.xxx.xxx.xxx 5060
      lifetime 300
      register auto
      register auto
  interface LAN
    bind interface IF_IP_LAN context router port 5060
  bind location-service LS_10002
  no shutdown
port ethernet 0 0
  medium auto
  encapsulation ip
  bind interface IF_IP_LAN router
  no shutdown
 port ethernet 0 1
  medium auto
  encapsulation ip
  bind interface IF_IP_WAN router
  no shutdown
port fxo 0 0
  use profile fxo us
  encapsulation cc-fxo
  bind interface IF_FXO_0 switch
  no shutdown
port fxo 0 1
  use profile fxo us
  bind interface IF_FXO_1 switch
  no shutdown
port fxo 0 2
  use profile fxo us
  bind interface IF_FXO_2 switch
  no shutdown
port fxo 0 3
  use profile fxo us
  bind interface IF_FXO_3 switch
  no shutdown
            context cs
                         no IF_FXO_1
                         no IF_FXO_2
                         no IF_FXO_3
               port fxo 0 1
                        shutdown
               port fxo 0 2
                        shutdown
               port fxo 0 3
                        shutdown
megalmazan
