Patton 4114
chico
hi, I setup the Patton on my 3cx and upload the file to the patton.
I can make or receive any call.
# For Patton 2 to 8 FXO
# Supported firmware versions R6.x
# Author: Tommaso Missoni
# Contact: [email protected]
webserver port 80 language en
system
ic voice 0
low-bitrate-codec g729
sntp-client
sntp-client server primary pool.ntp.org
profile ppp default
profile call-progress-tone defaultDialtone
flush-play-list
play 1 1000 350 -13 440 -13
profile call-progress-tone defaultAlertingtone
flush-play-list
play 1 400 400 -19 450 -19
pause 2 200
play 3 400 400 -19 450 -19
pause 4 2000
profile call-progress-tone defaultBusytone
flush-play-list
play 1 375 400 -24
pause 2 375
profile call-progress-tone defaultReleasetone
flush-play-list
play 1 400 400 -24
pause 2 350
play 3 225 400 -24
pause 4 525
profile call-progress-tone defaultCongestiontone
flush-play-list
play 1 400 400 -24
pause 2 350
play 3 225 400 -24
pause 4 525
profile tone-set default
profile voip default
codec 1 g711ulaw64k rx-length 20 tx-length 20 silence-suppression
codec 2 g711alaw64k rx-length 20 tx-length 20 silence-suppression
codec 3 g729 rx-length 20 tx-length 20 silence-suppression
fax transmission 1 relay t38-udp
profile pstn default
echo-canceler-hybrid-loss 0
echo-canceler-nlp silence
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_WAN
ipaddress dhcp
tcp adjust-mss rx mtu
tcp adjust-mss tx mtu
interface IF_IP_LAN
ipaddress 192.168.1.183 255.255.255.0
context cs switch
routing-table called-e164 RT_SIP_TO_FXO
route .% dest-service HG_TO_FXO
routing-table called-e164 RT_FXO_00_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_00
routing-table called-e164 RT_FXO_01_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_01
routing-table called-e164 RT_FXO_02_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_02
routing-table called-e164 RT_FXO_03_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_03
mapping-table called-e164 to called-e164 MT_CALL_ID_00
map .% to 000000
mapping-table called-e164 to called-e164 MT_CALL_ID_01
map .% to 000001
mapping-table called-e164 to called-e164 MT_CALL_ID_02
map .% to 000002
mapping-table called-e164 to called-e164 MT_CALL_ID_03
map .% to 000003
service hunt-group HG_TO_FXO
drop-cause destination-out-of-order
drop-cause user-busy
drop-cause normal-unspecified
drop-cause no-circuit-channel-available
drop-cause network-out-of-order
drop-cause temporary-failure
drop-cause switching-equipment-congestion
drop-cause access-info-discarded
drop-cause circuit-channel-not-available
drop-cause resources-unavailable
route call 1 dest-interface IF_FXO_0
interface sip IF_SIP
bind context sip-gateway GW_SIP
early-disconnect
route call dest-table RT_SIP_TO_FXO
remote 192.168.1.224 5060
trust remote
address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
address-translation incoming-call called-e164 request-uri
interface fxo IF_FXO_0
route call dest-table RT_FXO_00_TO_SIP
loop-break-duration min 60 max 1000
caller-id format etsi
ring-number on-caller-id
mute-dialing
disconnect-signal loop-break
disconnect-signal busy-tone
dial-after dialtone
interface fxo IF_FXO_1
route call dest-table RT_FXO_01_TO_SIP
mute-dialing
dial-after dialtone
interface fxo IF_FXO_2
route call dest-table RT_FXO_02_TO_SIP
mute-dialing
dial-after dialtone
interface fxo IF_FXO_3
route call dest-table RT_FXO_03_TO_SIP
mute-dialing
dial-after dialtone
context cs switch
no shutdown
authentication-service AS_ALL_LINES
realm 1 3CXPhoneSystem
username 10000 password ch3qyjd
location-service LS_10000
domain 1 192.168.1.224
identity-group default
authentication outbound
authenticate 1 authentication-service AS_ALL_LINES username 10000
identity 10000
registration outbound
registrar 192.168.1.224 5060
lifetime 300
register auto
register auto
interface LAN
bind interface IF_IP_LAN context router port 5060
bind location-service LS_10000
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
bind interface IF_IP_LAN router
no shutdown
port ethernet 0 1
medium auto
encapsulation ip
bind interface IF_IP_WAN router
no shutdown
port fxo 0 0
use profile fxo gb
encapsulation cc-fxo
bind interface IF_FXO_0 switch
no shutdown
port fxo 0 1
use profile fxo gb
bind interface IF_FXO_1 switch
no shutdown
port fxo 0 2
use profile fxo gb
bind interface IF_FXO_2 switch
no shutdown
port fxo 0 3
use profile fxo gb
bind interface IF_FXO_3 switch
no shutdown
context cs
no IF_FXO_1
no IF_FXO_2
no IF_FXO_3
port fxo 0 1
shutdown
port fxo 0 2
shutdown
port fxo 0 3
shutdown
Patton Log:
2017-03-08T14:55:16 : LOGINFO : Link up on interface ethernet 0 0 0
2017-03-08T14:55:17 : LOGINFO : Link up on interface IF_IP_LAN
2017-03-08T14:55:23 : LOGWARNING : Config: Line 19: SN4114/JO/EUI(ic-voice)[0]#sntp-client
2017-03-08T14:55:23 : LOGWARNING : Config: % ^ Keyword mismatch
2017-03-08T14:55:23 : LOGWARNING : Config: Line 21: SN4114/JO/EUI(ic-voice)[0]#sntp-client server primary pool.ntp.org
2017-03-08T14:55:23 : LOGWARNING : Config: Line 226: SN4114/JO/EUI(prt-eth)[0/0]#port ethernet 0 1
2017-03-08T14:55:23 : LOGWARNING : Config: % Ethernet port does not exist
2017-03-08T14:55:23 : LOGWARNING : Config: Line 259: 192.168.1.183(ctx-cs)[switch]#no IF_FXO_1
2017-03-08T14:55:23 : LOGWARNING : Config: Line 260: 192.168.1.183(ctx-cs)[switch]#no IF_FXO_2
2017-03-08T14:55:23 : LOGWARNING : Config: Line 261: 192.168.1.183(ctx-cs)[switch]#no IF_FXO_3
2017-03-08T13:55:23 : LOGINFO : Timezone: set local clock offset to +00:00
% local time changed from 2017-03-08T14:55:23 to 2017-03-08T13:55:23
2017-03-08T13:55:25 : LOGINFO : Warm start.
Can someone help me???
What ?! We're talking FXS now ???
.... ok, I'm out ...
devo.it
