Solved PBX has dropped a message with 'User-Agent:
TierList123
Hi There,
I have the following error in the logs pop up often:
26-Jun-2020 13:50:37.451 PBX has dropped a message with 'User-Agent: friendly-scanner' from IP 104.238.222.52 because it is on blocked UAs list
26-Jun-2020 12:03:20.306 PBX has dropped a message with 'User-Agent: friendly-scanner' from IP 104.238.222.52 because it is on blocked UAs list
What will be the cause of this?
If this is not an IP coming from your connected devices then it's a hack attempt stopped from 3cx security features
I'd recommend going through the 3CX training as this is one of the topics covered.
Reactions: NicholasP_3CX
Gone through that all a year or so ago. Can't remember this specific thing being covered.
Reactions: Prawnapple
Use 3CX's IP blacklist feature to stop any known baddies from entering:
this is not what 3CX ask to do in first step but you can also set your firewall rule for 5060 to be able to connect only with your sip provider IP , like this no more attempt, but of course if you run firewall checker it'll be red but with a known reason.
Thanks a lot will definitely check this out!
Hi There,
There are some known user agents that the system rejects automatically by user agent, and in this case the log entry informs you that this happened.
This is nothing to worry about, it's just your PBX doing its job of keeping you safe and this is one of many measures used to block unwanted traffic.
Thanks a lot for the response, appreciate it!
Reactions: JohnS_3CX
EMMEPICASA
