Phantom DN/Extension button
man416
Gold Partner
I have several customers with "legacy" systems that use phantom buttons for incoming calls. They use phantoms for a visual indication and sometimes different ring when covering multiple departments or other users. If all calls ring to their normal intercom/line key they have no way of knowing what department or user the incoming call is for. Is there a way to do something similar with the 3CX?
All depending on model of phone, if you route calls using ring groups / queues you can add the group / queue name to the incoming info that is display of the phone display
You can also prepend / Append the name of the Inbound rule if different department use different DIDs.
jmarshall
