Solved phone firmware
rbergthold
I used to navigate to the following link to check for the latest SUPPORTED firmware for devices before just allowing the system to do it. I got into this habit back in the day, as i updated a device once that my 3cx instance said had an available firmware. i pushed it out and the phone just went into a reboot cycle. I had found that when i went to the link below that that firmware ACTUALLY wasn't even supported yet, which was weird. That back-story aside, did the link for phone firmware change? i get a 404 error trying to go there now
https://www.3cx.com/support/phone-firmwares/
You are welcome!
mazet
