- Joined
- Feb 16, 2026
- Messages
- 7
- Reaction score
- 2
We are running a self-hosted 3CX system and all Yealink T4x phones use a custom provisioning template (yealinkt4x_custom.ph.xml).
While testing, I made a very minor change to the template (changed the label of Line Key 5 from "Park 2" to "TEST") and saved the template.
Immediately afterward, device management options under Admin Console → Phones became greyed out for all phones (Device Web Console, Reboot, Config, Reprovision). Phones remain registered and calling is unaffected.
Before taking any action during business hours, I want to confirm expected behavior:
Thanks in advance for any guidance!
- Does saving a custom phone template sometimes temporarily disable phone management actions?
- Is restarting the 3CX PhoneSystem service the correct/safe way to restore device management?
- Will restarting the service trigger automatic reprovisioning of phones or overwrite existing BLF/DSS key assignments?
