Phone Templates
travstoll
I use several custom phone templates. In v15, if I make changes and re-provision,
the template info on the phone seems to stay cached. I have tried changing the
templates for my Yealink T23G's in both the following locations, but the info for
the config still stays 'cached'. If I go to Phones "Specific Phone" > Config, I see
the old config even after a re-provision.
C:\ProgramData\3CX\Instance1\Data\Http\Templates\phones
C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\<AuthGenDir>
\CustomTemplates\phones
On v14, this was not an issue, if I made changes and reprovisioned, the changes would be reflected. There seems to be some sort of caching going on that isn't letting the phones grab the new changes in the template.
Restart ALL services - we are discussing this internally. For now restart the configuration service and that restarts all dependant services. (Nearly all except 2 non major services)
sunkiddance said:
Or do you mean you have to go into Administrative Tools-> Services in Windows to do this ?
That is correct, as from there any other services that are dependent on the one you are restarting will also be restarted.
I did a clean new install new of V15 and there are no templates in there at all. This version release is very premature, not impressed at all so far
Where exactly are there no templates, folder path? Also you said clean install, that means that you did not restore a backup right?
Ahzaz
