poe speaker for small factory
richo81
Anyone have any first hand experience with poe speaker for paging out to a small factory. Obviously needs to tie into 3CX.
Ideally the user picks up the handsets, calls the extension which goes to the speaker automatically and they can page staff members or notify them.
Is this possible if someone can point me in the right direction. TIA.
Cyberdata products work well and their support is good but they aren't cheap. I've heard good things about Algo as well but they are also a premium brand. You could try a Fanvil one as they are least have certified phones for 3CX so they might be able to help you get it dialed in. Otherwise any SIP standard speaker should do the trick with some TLC.
[email protected].
