- Joined
- Jul 2, 2021
- Messages
- 2
- Reaction score
- 0
Using 3CX CRM Template Generator, a template for integration with your own CRM system was created.
The problem is that every time an unknown number is requested, the 3CX address book is overwritten (advanced - > contacts), the numbers are not added to the id of the record, and the new record overwrites the previous one. In fact, I always have one entry in the address book with data from the last CRM request.
Template
Result
CRM journal
Template
XML:
<?xml version="1.0"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="US" Name="ERP" Version="1">
<Number Prefix="AsIs" MaxLength="[MaxLength]" />
<Connection MaxConcurrentRequests="2" />
<Parameters />
<Authentication Type="No" />
<Scenarios>
<Scenario Id="" Type="REST">
<Request Url="https://domain.com/api/org/contact/[Number]" MessagePasses="0" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Rules>
<Rule Type="Any">item.id</Rule>
</Rules>
<Variables>
<Variable Name="ContactID" Path="item.id">
<Filter />
</Variable>
<Variable Name="FirstName" Path="item.firstname">
<Filter />
</Variable>
<Variable Name="LastName" Path="item.lastname">
<Filter />
</Variable>
<Variable Name="CompanyName" Path="item.company">
<Filter />
</Variable>
<Variable Name="Email" Path="item.email">
<Filter />
</Variable>
<Variable Name="PhoneBusiness" Path="item.phone1">
<Filter />
</Variable>
<Variable Name="PhoneBusiness2" Path="item.phone2">
<Filter />
</Variable>
<Variable Name="PhoneMobile" Path="item.phone3">
<Filter />
</Variable>
<Variable Name="PhoneMobile2" Path="item.phone4">
<Filter />
</Variable>
<Variable Name="CustomValue" Path="item.custom">
<Filter />
</Variable>
<Variable Name="ContactUrl" Path="item.url">
<Filter />
</Variable>
</Variables>
<Outputs AllowEmpty="false">
<Output Type="ContactID" Passes="0" Value="[ContactID]" />
<Output Type="FirstName" Passes="0" Value="[FirstName]" />
<Output Type="LastName" Passes="0" Value="[LastName]" />
<Output Type="CompanyName" Passes="0" Value="[CompanyName]" />
<Output Type="Email" Passes="0" Value="[Email]" />
<Output Type="PhoneBusiness" Passes="0" Value="[PhoneBusiness]" />
<Output Type="PhoneBusiness2" Passes="0" Value="[PhoneBusiness2]" />
<Output Type="PhoneMobile" Passes="0" Value="[PhoneMobile]" />
<Output Type="PhoneMobile2" Passes="0" Value="[PhoneMobile2]" />
<Output Type="CustomValue" Passes="0" Value="[CustomValue]" />
<Output Type="ContactUrl" Passes="0" Value="[ContactUrl]" />
</Outputs>
</Scenario>
</Scenarios>
</Crm>
Result
JSON:
"UnparsedOutputs": {
"ContactID": "100001",
"FirstName": "Иван",
"LastName": "Иванов",
"CompanyName": "ООО «Рога и копыта»",
"Email": "[email protected]",
"PhoneBusiness": "",
"PhoneBusiness2": "",
"PhoneMobile": "79090123456",
"PhoneMobile2": "",
"CustomValue": "",
"ContactUrl": ""
"ContactUrl": "",
"PhotoUrl": null,
"ContactType": 0,
"PhoneHome": null,
"PhoneHome2": null,
"PhoneMobile2": "",
"PhoneOther": null,
"FaxBusiness": null,
"FaxHome": null,
"Pager": null
CRM journal
Code:
Started scenario with empty id
Request text: https://domain.com/api/org/contact/9090123456
Response text: {"item":{"id":100001,"firstname":"Иван","lastname":"Иванов","company":"ООО «Рога и копыта»","email":"[email protected]","phone3":"79090123456"}}
Response finished
Variable ContactID set to 100001
Variable FirstName set to Иван
Variable LastName set to Иванов
Variable CompanyName set to ООО «Рога и копыта»
Variable Email set to [email protected]
Variable PhoneBusiness set to
Variable PhoneBusiness2 set to
Variable PhoneMobile set to 79090123456
Variable PhoneMobile2 set to
Variable CustomValue set to
Variable ContactUrl set to
Finished scenario with empty id
Result obtained
