Problems with attended transfert managing IP phone with APP
Maxime@Tims
Gold Partner
Good evening lads,
I'm requesting your help because i have a problem to make a attended tranfert while using desktop app/webbrowser when talking with an IP phone (Yealink T54w)
My need is to control the phone with the app. Also i can't pick up the call with the app, pickup button is lock.
I'm certainly missing something if you might help.
Thanks in advance.
Maxime
Hi @Maxime@Tims
Can you confirm if the issue you are facing is what is described by in the forum post mentioned by cecon-Berlin?
Good morning sirs,
It may be related, so i'll try to downgrade the phone and i'll tell you if it worked.
Thanks for your help.
Good afternoon,
Thanks for the track it solved my problem BUT
Still can't use "hold" fonction and cant send DTMF neither
Cheers
