- Joined
- Feb 6, 2019
- Messages
- 19
- Reaction score
- 0
hello
i have problem with sip gateway on bulgaria.
i can make outbound call
when i try to make incomming call, call are drop ... in do no logs. i activate DID authentication.
tks advance for reply
30/07/2019 15:20:29:618 | 10 | LineMgr: identifying the source of SIP request: SI Recv Req INVITE from 10.102.249.23:5060 tid=0nmad510co6vmbdl4h80.1 Call-ID=SD0t7cb01-364e1dda50a14c1bca648e234c0d0a34-ags9010030:
INVITE sip:[email protected]:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.102.249.xx:5060;branch=z9hG4bK0nmad510co6vmbdl4h80.1
Max-Forwards: 66
Contact: <sip:[email protected]:5060;transport=udp>
To: <sip:[email protected];user=phone>
From: <sip:[email protected];user=phone>;tag=SD0t7cb01-eldu20ke-CC-1013
Call-ID: SD0t7cb01-364e1dda50a14c1bca648e234c0d0a34-ags9010030
CSeq: 1 INVITE
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, PRACK, SUBSCRIBE, NOTIFY, UPDATE, MESSAGE, REFER
Content-Type: application/sdp
User-Agent: Vivacom.United.Communications
Content-Length: 223
v=0
o=vivacom 7915988 7915988 IN IP4 10.102.249.23
s=Sip Call
c=IN IP4 10.102.249.23
t=0 0
m=audio 20188 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
30/07/2019 15:20:29:618 | 10 | Matched: User of To to 003597xxxx,07206xxxx,0720xxxx,07206xxxx,0720xxxxx,072xxxx
Level = 8
Severity = Debug
Tread = 10
Source = <unknown>, line:544
30/07/2019 15:20:29:618 | 10 | Trunk Lc:10000(@Generic Gateway Device[<sip:[email protected]:5060>]) has matched as source by DID only
Level = 5
Severity = Trace
Tread = 10
Source = e:\jenkins\workspace\16.0.sp2\sources\projects\pbxserver\src\linemgr.cpp, line:382
30/07/2019 15:20:29:618 | 10 | Source is identified as trunk Lc:10000(@Generic Gateway Device[<sip:[email protected]:5060>]) (single match by DID)
Level = 5
Severity = Trace
Tread = 10
Source = e:\jenkins\workspace\16.0.sp2\sources\projects\pbxserver\src\linemgr.cpp, line:395
30/07/2019 15:20:33:026 | 10 | Default best-route IP is determined as 192.168.50.180
Level = 5
Severity = Trace
Tread = 10
Source = e:\jenkins\workspace\16.0.sp2\sources\projects\pbxserver\src\callmgr.cpp, line:1502
30/07/2019 15:20:33:112 | 5 | Currently active calls [none]
Level = 5
Severity = Log
Tread = 5
Source = <unknown>, line:56
Max-Forwards: 66
CSeq: 1 INVITE
Content-Length: 223
v=0
s=Sip Call
t=0 0
a=fmtp:101 0-15
Level = 8
Severity = Debug
Tread = 10
Level = 5
Severity = Trace
Tread = 10
Level = 5
Severity = Trace
Tread = 10
Level = 5
Severity = Trace
Tread = 10
Level = 5
Severity = Log
Tread = 5
