Provisioning file publicly accessible
sanch6
This might be a silly question, but I have a 3CX instance in the cloud (on Azure) and have added a Grandstream gateway. The gateway uses a provisioning link that points to an XML file. If I paste this link into my browser, I can see the credentials in plain text. Isn't this a bit problematic?
What if, for some reason, a bot or some other entity happens to come across this URL?
Could someone actually do anything with the credentials found in that file?
Thanks for your insights, sorry if this is a silly question and have a great weekend.
The file needs to be public. However, that's why the URL contains a random string, called the provisioning folder, which prevents randomly accessing the file without having its exact URL. The chances of a bot finding it is small.
Also, gateways connect locally or via SBC, so even if someone has the credentials, they won't be able to do much.
Hi @sanch6 in adition to what @Evolute IT said, you can also enable the parameter secure device provisioning files using unique keys, this will make that every device has its own URL making the process even harder to get the specific provisioning file.
Reactions: N_G and Evolute IT
youwillbrun
