Provisioning Interface Change
paulsummers
When creating new extensions, the 3CX App network settings, the local IP of our Azure box is shown, e.g. 10.0.0.4, and not the FQDN company.3cx.co.uk, how do I change this to always default preset the domain for 3CX App 'phones'. Our physical desk phones use an SBC. Google is giving a clear answer on this occasion! Any assistance much appreciated.
Whilst investigating, I also search settings > parameters to see what else is configured with this local 10.0.0.4 IP, seems quite a few things:
CMEXTERNALINTERFACE
DEFAULTLOCALIP
MSEXTERNALINTERFACE
SIPDOMAIN2
WEB_ROOT_LOCAL
WEB_ROOT_LOCAL_SEC
MYPHONE_LINK_LOCAL
MYPHONE_LINK_LOCAL_SEC
REPORTER_LINK_LOCAL
REPORTER_LINK_LOCAL_SEC
PROVISIONING_LINK_LOCAL
PROVISIONING_LINK_LOCAL_SEC
MANAGEMENT_LINK_LOCAL
MANAGEMENT_LINK_LOCAL_SEC
Should these not be a public accessible route? We migrated from on-premises to Azure last year via export/restore config so possibly a hangover from this.
Under Settings > Network what is your default listed there?
is it the same as whats under EXT > Provisioning > Network interface?
'Select Network Card Interface > Default Internet facing IP Address. (Default gateway)' is set to: 10.0.0.4 (There is no other option). Extensions are by default set to this.
'External IP Configuration > Static Public IP' is set to the Azure box public IP.
So its not reflecting your external IP?
Not sure what choice you have - does it appear after rebooting th VM and or 3CX?
if not you might have to backup 3CX without network settings and restore it
bosdorf
