Provisioning of Gigaset DECT N510 is not working
Jack4ever
SOHO User
is there somebody who can help provisioning a DECT N510 ?
I followed the steps described in the link below
https://www.3cx.com/sip-phones/manually-provision-gigaset-n510/
If the provisioning would be working I assume the device will added in the phone list ??
in the log file I don't understand everything what is written - but I can't find anything in the list with the MAC address of that device (FXS/DECT extension)
So where is it ? I guess the provisioning is not working.
I am running a PBX hosted by 3CX
finally fw turn into 250 version
it is not working
these settings are good but extension settings are missing on top of same page.
did you refresh provisioning url in management ?
see also in 3cx console your N510 IP hasn't been blacklisted, if you see IP in blacklist remove it.
good morning Christian!
I did refresh of provisioning
And deleted the blacklist.... I Will refresh prov again now...
You think I need new firmware ?
The prov. link is working when I click on it in 3CX . I see that the XML file is dowloading - learned this from you ;-)
So that's done, perfect, nothing else than use handset now :)
nope... not working :(
the handset is showing - registration at provider failed.
today they will supply our new phones - that will help.
As long the ipaddress is not correct it will not work.
I think I better give up Christian...
In meanwhile in am trying to port our phone numbers to another provider.
You have no idea how long this is already taking.
5 Calls -with an average of 30 Min of waiting.
bold line for gigaset N510 is not a problem, you can delete it clicking on X on right end of the line.
did you received extensions from provisioning ?
except this bold line nothing else changed
I deleted the line (now) as you said (older picture)
i've done the same and provisioning is not working, but creating extensions manually in N510 works , have done it now, you just need to untick this in security settings
I unchecked the security option.
But still nothing.
the acitvity log file is showing this
Itseems author. id and passw don't match
I filled in the authentication name , passw etc.
except the user name I am not sure
swegner
