Solved PWA & Web stopped working since v20
Gallart
Since we upgrade to V20, our users need to use the "Windows Store" App to be registered within our 3CX. If they login with PWA or Web App, their users are showing "not registered" from central portal depiste diplayed "Green" on their workstation.
Installing 3CX App from Windows Store fixes the issue and make them online, able to answer incoming calls.
Any idea?
When you login to the Web Client, have you confirmed that the notifications are allowed?
Reactions: jed
It was already allowed from v18 and not re-asked for v20.
Can you please check again or try to disable/enable again?
Works. Enabling notifications (again) fixes the issue.
Thanks!
Reactions: jed
cur_cb
