QR Codes Version
ITHelp
I had version 14 of 3CX and wanted to get the version with QR codes. Online it says it started with version 15.5 SP2. I had the .exe of version 15.5 so I installed it today. But where can I get the SP updates? Anyone know? I don't want to install version 16 because its free version has a limit of 25 extensions and I have around 30 extensions.
If you downloaded v15.5 it should already be on on SP6. If the version in the dashboard shows 15.5.15502.6 (the last digit is the SP #) then you are all set.
Hi ITHelp
If you are moving from an older version to a newer, I would highly recommend to go to V16 which has the latest security updates and features.
You might want to check your license key type first to see if you can upgrade.
[email protected].
