Queue forwarding to a queue; user not ringing in the second queue.
lucas.ruffieux
I have this workflow with the users and queues listed in the config:
User 1, User 2, Queue 1, Queue 2, DID 1
Workflow: DID 1 goes to Queue 1 (User 1 is the only member). After 2 minutes with no answer, Queue 1 forwards to Queue 2 (members: User 1 and User 2; ring-all).
If User 1 disconnects from queues, the first queue transfers directly to Queue 2 because no one is logged in. But User 2 doesn’t ring in Queue 2 (checked: logged in to the queue — OK). If we reconnect User 1, after 2 minutes both users in Queue 2 will ring.
I set this up to allow interception when User 2 has too much work, while still answering if User 1 is also overloaded.
Does anyone know what the issue is and how to solve it permanently?
For now, if User 1 is disconnected, I need to remove User 2 from Queue 2 and re-add them; that fixes the issue.
Hello @lucas.ruffieux
The User 2 should be able to receive the calls from Queue 2, to be able to see what the issue is and advise, we will need to check the Support Info files in Verbose logging level also. Please open a ticket with the described behavior so we can check it further.
Reactions: lucas.ruffieux
asandris
