Random incoming calls to main ring group ring once then go to voicemail
Joey D.
Hello everyone,
Having and issue with a system where once or twice per day a call will come in to the main (only) ring group (with six members), ring the six extensions once, then go directly to voicemail. There are dozens of other calls that are received without issue.
What could cause this?
It's an amazon lightsail hosted system, 18.0 (Build 418), with the six extensions (yealink t46s) behind a raspi SBC.
This is the activity log for the most recent time it happened, but the logs are full of these messages. I've removed the domain name-
10/21/2022 11:24:38 AM - [CM503003]: Call(C:2146): Call to <sip:104@:0> has failed; Cause: 487 Request Cancelled/INVITE from 127.0.0.1:5080
10/21/2022 11:24:38 AM - [CM503003]: Call(C:2146): Call to <sip:105@:0> has failed; Cause: 487 Request Cancelled/INVITE from 127.0.0.1:5080
10/21/2022 11:24:38 AM - [CM503003]: Call(C:2146): Call to <sip:106@:0> has failed; Cause: 487 Request Cancelled/INVITE from 127.0.0.1:5080
10/21/2022 11:24:38 AM - [CM503003]: Call(C:2146): Call to <sip:103@:0> has failed; Cause: 487 Request Cancelled/INVITE from 127.0.0.1:5080
10/21/2022 11:24:38 AM - [CM503003]: Call(C:2146): Call to <sip:102@:0> has failed; Cause: 487 Request Cancelled/INVITE from 127.0.0.1:5080
10/21/2022 11:24:38 AM - [CM503003]: Call(C:2146): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
Thank you!
The activity log does not give enough information in this case and requires further investigation. I would suggest that you create a ticket in 3CX Technical Support to advice further.
VR46
