Raspberry Pi 4 performance
bro
Hi all,
Is anyone aware of the kind of performance we're looking at on v16 Update 6a running on a Pi 4? Specifically simultaneous calls, video conferencing, maximum extensions, BLFs, etc.
I'm not expecting massive gains over the Pi 3, but we don't know what user bracket we're able to quote for with a Pi 4.
Since the Pi 3 support was added, there have been a number of 3CX updates that have improved performance, and the Pi 4 seems to have a substantial performance improvement over the Pi 3 on paper. How much does this translate to 3CX performance?
On a semi-unrelated note, how much of the performance bottleneck on a Pi is due to the SD card? Would it be beneficial to boot off a USB 3 drive on the Pi 4, or is performance mostly CPU-bound?
Cheers!
No performance stats have been released on Pi4 version as yet, believe 3cx are working on this
Legendary! Cheers, mate! Where did you hear they're working on it?
You will have to wait a bit longer before we give official numbers for the Pi 4, as it is not yet a supported device (but getting closer, so keep an eye on our blog posts)
Awesome, thank you. :)
Just an FYI, we've been under the impression it is officially supported. This page states a Pi 4 is needed.
From this point on, we'll assume that it isn't officially supported until we see a blog post! :)
Cheers!
  • Haha
Reactions: DSXVOICE
Just prepping the guides for what's to come ;)
[email protected].
