Raspberry Pi Vlan
greatchoice
Is is possible to make the network a vlan on the Pi SBC?
I am sure it is, what would be the point?
Because if the phones are on another vlan they won’t know how to communicate with it. Duh. I’m trying to figure out if it’s possible and how it’s done
Duh Works for us!!!!!!
Maybe you need a lesion in networking
Providing your VLAN's can communicate to each other, you PI can be on a different subnet than the phones. However we always try to group them tougher some times it is not possible.
Why not set the switchport that the sbc is plugged into to access ?
Reactions: Saqqara
As above, set the vlan on the switch port
Maybe you need connect the SBC on Switch port whit voice vlan untagged.
fransisco
