- Joined
- Dec 11, 2023
- Messages
- 3
- Reaction score
- 0
Is there anyone who can help me with a Realworks XML for the CRM integration?
We’ve made decent progress, but Realworks is giving us trouble.
Below is the XML.
Below is the XML.
Code:
<?xml version="1.0" encoding="utf-8"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="US" Name="Realworks" Version="2" SupportsEmojis="true" ListPageSize="0">
<Number Prefix="AsIs" MaxLength="20" />
<Connection MaxConcurrentRequests="16" />
<Parameters>
<Parameter Name="CreateContactEnabled" Type="Boolean" Parent="General Configuration" Editor="String" Title="Allow contact creation directly to your CRM using 3CX Web Client" Validation="" Default="False" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
<Parameter Name="ReportCallEnabled" Type="Boolean" Parent="" Editor="String" Title="Enable Call Journaling" Validation="" Default="False" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
</Parameters>
<Authentication Type="No" />
<Scenarios>
<Scenario Id="" Type="REST" EntityId="" EntityOrder="">
<Request SkipIf="" Url="https://crm.realworks.nl/webservices/rest/ippbx/signaleergesprek/[ServerId]/[UserId]/[AuthToken]/01[CallId]/[Number]/220[Agent]/2/[[CallDirection].Replace("Inbound","false").Replace("Outbound","true")]/0[CallStartTimeLocalMillis]" MessagePasses="0" Message="" RequestContentType="" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Rules>
<Rule Type="Any" Ethalon="">id</Rule>
</Rules>
<Variables>
<Variable Name="Id" LookupValue="" Path="id"><Filter /></Variable>
<Variable Name="ServerId" LookupValue="" Path="[ServerId]"><Filter /></Variable>
<Variable Name="UserId" LookupValue="" Path="[UserId]"><Filter /></Variable>
<Variable Name="AuthToken" LookupValue="" Path="[AuthToken]"><Filter /></Variable>
<Variable Name="CallId" LookupValue="" Path="[CallId]"><Filter /></Variable>
<Variable Name="CallFrom" LookupValue="" Path="[CallFrom]"><Filter /></Variable>
<Variable Name="CallTo" LookupValue="" Path="[CallTo]"><Filter /></Variable>
<Variable Name="Status" LookupValue="" Path="[Status]"><Filter /></Variable>
<Variable Name="Outgoing" LookupValue="" Path="[Outgoing]"><Filter /></Variable>
<Variable Name="IsOutgoing" LookupValue="" Path=""><Filter /></Variable>
<Variable Name="Timestamp" LookupValue="" Path=""><Filter /></Variable>
</Variables>
<Outputs AllowEmpty="false" />
</Scenario>
</Scenarios>
</Crm>
