Solved Recording Remaining Space not working
penfold15
SMB User
Hi All,
The management console is not displaying the remaining space on the recordings section, it just shows as -
The drives are mounted and the correct usable space is shown when using df -h on the command line. Recordings work fine but just stop when it runs out of space, no notifications as it cannot see the space remaining.
How do I get 3cx to see the space remaining?
Ok as per our PM the feature now works as intended. For other users reading this:
- Make sure you create a dedicated recordings subfolder in your mounted drive. Avoid using the root folder of a drive in linux
- Give it ownership and grouping with RWX rights for the user "phonesystem" or if in doubt copy the rights/ownership that the default folder has
- Point your recordings to this new folder via the management console
Reactions: penfold15
EMMEPICASA
