RegistrarInvite Property
oJo
We are experiencing issues with one of our SIP Trunks, the local provider is saying the 3CX System is sending them a deregister. We are using the exact same configuration as another 3CX PBX at another location with the same product, where it works fine. The only difference I could find is the property
<field name="RegistrarInvite">1</field> when you export the provider. For the working connection it is set to 1, for the one not working it's set to 0. I was unable to change it or find a setting in the GUI.
Can anyone explain what this setting does and how to change it? Could this be causing our issues?
martin99
