reinstallation
mj86
Trial User
i was forced to reinstall the full windows server.
so
how can i download the 3cx server again
and get my config?
i have a 30 day trial
i should be surprised if this are not possible
so
and get my config?
Do you have a backup of the old server?
You can download the PBX from the "Downloads" section of your customer portal. You should have backed up your configuration beforehand; otherwise, you'll have to start over from scratch.
If you were doing local backups in 3CX but backing up your Windows Server, you might be able to get your ZIP file from C:\ProgramData\3CX\Instance1\Data\Backups
Otherwise, this is a lesson learned and you'll start from scratch.
amazingbv
