remote provisiong one voip phone
RM-Da
hi
I've a question my customer has a remote office with a few persons and he asked to reuse a yealink T31G as a remote phone to install on this site.
They have an instance clound of 3CX and in this office don't have a SBC software, I've tried to add that on 3CX, it pushes the configuration correctly but on console and on display I see that the extention is not registered, the configuration is present. There is not firewall present.
Is there a way to see the extentenion registered on phone without use a SBC?
thanks.
Hi Riccardo,
Do not register it directly - this is no longer supported by 3CX. A word of caution, you will face connectivity and audio issues and then you will be wondering why it stopped working suddenly when it was apparently working fine the day before.
You can install a Raspberry Pi at that office to act as the SBC or since the phone belongs to the company, you can swap it for another model that is also a router and not need to use a Pi or buy a new phone.
See which models are routers from here:
https://www.3cx.com/sip-phones/yealink-t4-series/
https://www.3cx.com/sip-phones/yealink-t5-series/
https://www.3cx.com/sip-phones/yealink-ax-series/
Hi Riccardo,
ok perfect. thanks a lot!
Reactions: JohnS_3CX
No members online now.
RJenkinsROCK
