- Joined
- Sep 11, 2023
- Messages
- 5
- Reaction score
- 0
Since U7, I've been getting the message 'Remote storage is partially configured. It is required to keep your system performant and easily updateable.' on the dashboard. As I read here, I need to check all available options for Data Archiving to remove this message.
In this context, I then discovered that I can no longer press the 'Save' button there. The error message 'Invalid login credentials' always appears, even though everything worked fine under U6.
I'm using SMB as the location type.
I have already tried re-entering the password, but unfortunately, that didn’t help either.
Can anyone tell me what changed with U7 or how I can get SMB working again? I can’t find anything in the changelogs indicating that anything changed here.
Unfortunately, I also can't find anything in the logs.
Best Regards
Patrick
Best Regards
Patrick
