Remove a scheduled backup - debian version
shortcirciut
Hi All,
I need to remove a scheduled backup instance but cannot find a way.
Its because I have 2 running, after I had restored an older backup from windows.
Any ideas ?
Thanks in advance
So you're just trying to disable scheduled backups?
No there are 2 running schedules rat different time. I just need 1. If I can delete them both and then re do one it does not matter.
You have 2 backup schedules for one pbx?
Using the "Backup and Recovery" tab in the management console? How were you able to create two backup schedules?
Which 3CX version are you running ?
Its 16.0.612 on Debian
How do you know exactly that you have two scheduled tasks?
because I am getting 2 email reports at different times for the same day
That's a bit strange, you will have to check a few things then.
- Any chance the time of the server drifts and recovers? (SystemService log will show discrepancy)
- Can you confirm the same machine creates the backups? (System service log will show it)
- Do you have any other machine that can create backups?
- Does the email have the same FQDN in both cases?
Wecare_ITA
