Replace license key
nathan0707
My NFR key was suspended, I am trying to change my license using the replace license options on the pbx, on one of them I had the option added the new key and was done, on our internal instance I am missing the replace license option
If it's 3CX hosted you won't have that option.
Well basically 3CX hosted or using a version before the replace key feature was added are the only two scenarios I've seen that button not be visible.
Thanks will see what support comes back with.
Do you have failover enabled under the backup and restore section > failover tab?
Reactions: JohnS_3CX
Reactions: nathan0707
I sent a message to support on Thursday and I have not heard back
Hi @nathan0707
I believe someone has already contacted you about the matter via email at the time of me writing this.
Oliver Hastedt
