Reporting - Type (Trunk/DID)
JCubio
Hi experts,
I tested the reporting feature of 3CX and I used the Trunk/DID type.
This is the result.
13120
What does the number represent? Is it the outbound or inbound call?
Go to your trunk page to see, it should match your DID that you entered there
I'm referring to the total number sir. What is that number 1 for?
Incoming calls to your DID
I see.
Is there any other way to generate a report on how many outgoing calls have been made on the trunks?
You could use the "Call Reports" which will show you the outgoing calls made with a total tally on the bottom and filter From:Any To:ExternalNumbers
Wecare_ITA
