Solved reset fanvil i18s
VictorC
SOHO User
Anyone have a clue on how to reset a Fanvil i18s? It's the one with no keys.
the stuff on 3cx will not work, as there is no keys on the i18s, I opened a ticket with their support, but I'm not holding my breath on an answer from them.
Oh that's right, you said no keys :) . Yeah I searched through the manual and didn't see anything other than doing it via the web interface. If you purchased through distribution they may be able to help.
I emailed 3cx and Finvil, so we will see
You will need to pull out the motherboard - It has 2 buttons on it "#" and "*"
The hardware reset code is #****#* . After press it , there will be a beep and device will do the reset reboot automatically.
ok thanks, I'll have a look
Hello, I see those buttons now, but the reset does not seem to work. I do get 2 quick beeps, but nothing after that.
Set you PC to a static IP of 192.168.10.2. Press * and # simultaneously whilst powering on.
Then use telnet to connect to 192.168.10.1 and clear the config. Just done this today on one and confirmed that it works. Also attached instructions from fanvil
Thanks BennyG, that saved my butt. ..
Reactions: BennyG
footandankle.my3fcx.us
