Resetting instance without config file
Scott EIT
Hi all,
I'm a Bronze Partner trying to recover a customer's 3CX system after a compromise and I'm struggling with the new V20 deployment process.
Background:
  • Original 3CX system was compromised.
  • I have a valid 16-character licence key for the customer.
  • Original server is no longer available.
  • I have a pre-compromise backup from 2025 and a support info ZIP from the old system.
  • Restoring the old backup has already caused numerous issues and I'd prefer to rebuild from scratch.
Current situation:
  • I've deployed a fresh V20 instance on Vultr.
  • During initial setup I am only presented with:
    • "Upload a new Configuration file created on 3CX"
    • "Restore a backup"
  • I do not have access to the customer portal account that originally owned the licence.
  • I only have the 16-character licence key.
  • I do not have the original welcome email or .3cxconfig file.
Questions:
  1. Is there any way to generate or recover a valid V20 configuration file using only the licence key?
  2. Can a Bronze Partner recover ownership/access to a licence when the original portal account is unavailable?
  3. If I restore a backup from a different V20 system purely to get through onboarding, can I later replace the licence with the customer's existing paid licence and rebuild the configuration manually?
  4. Has anyone successfully activated a fresh V20 deployment using only a licence key where the portal account access was lost?
At this point I'm trying to determine whether there is a technical workaround or whether I need 3CX to intervene and reassign/recover the licence record before I can proceed.
Any advice would be greatly appreciated.
Thanks.
Scott
amazingbv
