Right to Left chat text format
John Smith-Sepidar
Trial User
There's a problem in 3cx chats. The alignment and the order of the Arabic words, English text, numbers, punctuation, and timestamps are not correct. Is there a solution for it?
Thank You!
Thank You!
Are you using the Web, Windows or Mobile apps? What versions?
If you could create some anonymised screenshots with placeholder conversations so we can see exactly what you are referring to, that would be helpful.
Thank You for your response.
I'm using the Web App and the version is 20.
I attached the image of my problem as below:
The correct format that must be displayed after typing must be like this:
when I type a sentence that contains English words, the words are shown in a wrong order.
NetworkActive
