- Joined
- Aug 12, 2019
- Messages
- 6
- Reaction score
- 7
Thank you 3CX for platform! I've been installing and setting these up for the last few weeks however I have a small quirk that either needs clarification, workaround or maybe its in the pipeline.
v16.0.507 Pro.
1.
Setup = 4-6 SIP lines 6-10 extensions, all extensions in an 'Inbound Ring Group' basic group (not queue as the queue causes another problem below).
Problem: If two or more inbound calls come in at the same time (thereabouts) and all extensions are ringing = the busy tone is played to the other calls.
- more than enough SIP trunks coming in - why cant a group keep hold of the other calls and keep ringing once an extension has the first call?
- the client is not keen on enabling multiple calls per extension due to interruptions.
Using CRM integration (MySQL ODBC) to pop calls to contact record when answered successfully .
or
2.
Setup = 4-6 SIP lines 6-10 extensions, all extensions in an 'Inbound Call Queue'
The initial problem of momentarily busy quirk goes away but breaks the CRM integration;
Problem: on every call inbound of extensions in the queue 3CX ignores the 'on call connected' and pops the contact record every call this would ok if it was pop on ringing but not working on call connected selected.
3.
Finally loss of CRM integration when transferring calls after the initial call has been answered not passing the original caller ID through?
Using attended transfers.
Thank you in advance.
#BeKind
v16.0.507 Pro.
1.
or
2.
3.
#BeKind
