Solved Ring Group - Press zero to go to operator at any time
Alan9846
Hi All,
I had a question today that I could not answer.
A client has a (prioritised hunt) ring group setup with a number of members, all of which get 10 seconds before it moves on to the next (then finally to a dummy extension's voicemail), and wants to know if they can let callers press zero (or any other digit I guess) to exit from the ring group at any time (prior to getting to the voicemail) and go to the operator.
Am I missing an obvious option to do this?
Thanks,
Alan.
They can also use that to go to the operator once transferred to the voicemail. The messge could alert them to the option, or let them leave a voicemail.
Reactions: ChrisC_3CX
Just to let you know - I went with this option and the client seems happy (for now at least!)
Thanks,
Alan.
PS: I'd close the question, but I cannot currently work out how to do that.
@Alan9846
I'll be marking this as solved.
Feel free to start a new thread should you need anything else!
Rich Hopkins
