Dan Nica Free User Joined Jan 7, 2019 Messages 22 Reaction score 1 Feb 13, 2019 #1 Hi, I have two sip trunk providers and I want to route one extension through one of the providers, how can I do that automatically? Thanks, Dan
cobaltit Platinum Partner Advanced Certified Joined Mar 22, 2012 Messages 6,735 Reaction score 2,324 Feb 13, 2019 #2 I'm assuming you mean outbound so you would do it the same way you would route any outbound call and that would be via outbound rules.
Saqqara Bronze Partner Basic Certified Joined Mar 12, 2014 Messages 4,775 Reaction score 1,471 Feb 13, 2019 #3 As above, config outbound rules using extension rule https://www.3cx.com/docs/manual/sip-trunks/#h.3evqdta9sabf
Dan Nica Free User Joined Jan 7, 2019 Messages 22 Reaction score 1 Feb 13, 2019 #4 well I want it for in and out rules, it is different?
Saqqara Bronze Partner Basic Certified Joined Mar 12, 2014 Messages 4,775 Reaction score 1,471 Feb 13, 2019 #5 Yes Inbound rules are for incoming calls to 3cx https://www.3cx.com/docs/manual/inbound-did-call-routing/ Outbound rules are for outgoing calls form 3cx Make sure the outbound rule is above the generic rules, as rules are process for the top to bottom
cobaltit Platinum Partner Advanced Certified Joined Mar 22, 2012 Messages 6,735 Reaction score 2,324 Feb 13, 2019 #6 Well inbound is easy since since DIDs are unique and can only be on one trunk. But yes as far as routing that DID to a specific extension you would do that via inbound rules.
Dan Nica Free User Joined Jan 7, 2019 Messages 22 Reaction score 1 Feb 14, 2019 #7 ok, thanks, manage to get it working
YiannisH_3CX Support Team Staff member 3CX Support Joined May 10, 2016 Messages 11,811 Reaction score 1,797 Feb 18, 2019 #8 Glad to see the issue has been resolved.
