Router Phone vs SBC
prb1412
I read that a router phone can handle 10 extension. I have an instance with 20 extensions. Should I use (2) router phones, or just setup a Windows SBC?
What is the justification / performance.
You can do either of those options. Two router phones should have you covered in case you don't have a PC / Server at the phones location.
Just make sure to assign 9 users under 1 router phone, and the other 9 to the other router phone and you should be ok!
AshleyStokes
