RPS Yealink automatic update ?
Nico!
Titanium Partner
Today i want to add some devices on the new yealink RPS service and i've got the following reply from the website:
And right after that i saw in the event log the following entries:
Does 3CX automatically add new devices to the RPS ?
If so, it's good news, or i missed somethings.
Yes, if the provisioning type selected is direct SIP.
If you're using an SBC, you can enter the info but choose direct SIP, save, then edit with the SBC info and the phone will provision as expected.
Thank you for your answer, i didn't know that.
I'm not very familiar with direct SIP phones.
Hello @Nicolas V.
When you add a phone and select Direst SIP (STUN-Remote) as the provisioning method the phone system will automatically send a request for the MAC address to the RPS server (if the model is supported). Once the phone is restarted and if it is factory reset if will request the configuration from the RPS server. It will then prompt you for a username and password.
Zexus
