Running multiple 3CX instances on one server
Adrian Tregent
Hello everyone,
I'm looking for a solution to run multiple 3CX clients from one single server... wondering if that would be possible and the best way to do it... any idea would be appreciated. Thx!
I'm not sure if there's a native-SECURE way to separate different customers in one single server or to run multiple instances in the same server.
Hello @Adrian Tregent
Please note that you can have multiple PBX installations on a single server using virtualisation and have 1 pbx per virtual machine. You will need however a separate public IP address for each PBX you install in order to have them working properly.
I would recommend creating your instances on a supported cloud service where each PBX will have its own public IP and will be easily manageable. https://www.3cx.com/phone-system/cloud-pbx-server/
Reactions: Adrian Tregent
jmarshall
