Solved Same EXT intercom on site
Networkbug
Is it possible to use two sets of phones on same EXT on same network for intercom calls instead of assigning different extension.
Thanks.
Yes, both will ring when a call is made to the extension, and both can use that extension to place calls.
That's SIP forking if you're curious.
Reactions: Networkbug
Ahh I see, I have setup of DECT and hard phone. Both work perfect when you call the EXT.
I actually want the staff to use the same phone to ring other DECT phone inside.
They can call the same extension (just make sure that Accept Multiple Calls is enabled on the extension's forwarding rules.)
Reactions: jed and Networkbug
Yup this worked, thanks a lot. I looked almost everywhere in web portal.
Reactions: jed and Evolute IT
mazet
