SAST/CAT Timezone Issue on Fanvil X3S/X3SP
TekkNinja
Hi everyone. I posted this thread a while back and never got a chance to investigate further
I have looked into the latest template fanvil.ph.xml on 16.0.5.612 with the phones on version 2.10.1.6836.
Code:
<option value="32" displaytext="GMT+2 Harare, Pretoria" zone="2:00" id="65">
        <item name="timezonename">EET_002</item>
        <item name="dstenabled">0</item>
        <item name="dstoffsetminutes"></item>
        <item name="dststartmonth"></item>
        <item name="dststartweek"></item>
        <item name="dststartday"></item>
        <item name="dststarthour"></item>
        <item name="dststartmin"></item>
        <item name="dstendmonth"></item>
        <item name="dstendweek"></item>
        <item name="dstendday"></item>
        <item name="dstendhour"></item>
        <item name="dstendmin"></item>
        <item name="timezonex3s">8</item>
        <item name="timezonenamex3s">UTC+2</item>
        <item name="locationx3s">10</item>
        <item name="dstx3s">1</item>
      </option>
The timezone settings in the provisioning config file sent to one of the X3S phones shows the following:
Code:
<Time_Zone>8</Time_Zone>
<Time_Zone_Name>UTC+2</Time_Zone_Name>
<Location>10</Location>
<Enable_DST>1</Enable_DST>
<DST_Type>1</DST_Type>
It seems that having SAST/CAT on the PBX is provisioning the X3S/X3SP phones with DST enabled which seems to stem from the following line in the fanvil.ph.xml provisioning template
Code:
For Comparison the X5S gets the following config which i feel for SAST/CAT should actually be a 0 and not a 2 as we dont do any DST
Code:
#Configure the daylight saving time feature; 0-Disabled, 1-Enabled, 2-Automatic (default);
local_time.summer_time = 2
Manually disabling DST on each phone solves my issue but is a headache to do on multiple phones and when the phone gets re provisioned it means having to go through the whole process again..
Just to add to this. When i manually disable DST on the X3S and export the current config of it in xml i get the following (snipped to relevant info)
Code:
<Location>0</Location>
<Enable_DST>0</Enable_DST>
<DST_Fixed_Type>2</DST_Fixed_Type>
On an X3S that has been provisioned and the current config on the phone exported as xml i see the following:
Code:
This would indicate that the following changes could be made to the provisioning template for my timezone:
Code:
       <item name="locationx3s">0</item>
        <item name="dstx3s">0</item>
      </option>
Edit: For clarification the 2 changes would be:
item name="locationx3s" changed from 10 to 0
item name="dstx3s" changed from 1 to 0
Any feedback on this?
Wecare_ITA
