SBC HA Cluster State
Phil-STIC
Platinum Partner
I am currently testing a configuration of 2 RaspberryPI SBCs, mounted in a cluster.
It seems to work very well and I would like to install this configuration at a customer site.
The thing that bugs me is that if one SBC goes down, I get a notification that the cluster is up, but no details. I can't tell if both are working or if only one is accessible. So I don't know if I need a replacement.
The only way I found to check the status of the cluster, is to connect in ssh on a raspberry and do the command "crm status".
I would like to receive a notification that an SBC of the cluster has fallen, and be able to validate this information, without having an SSH connection.
Thank you for your help.
I didn't know it was still in Beta...
I'll wait a bit in that case.
Thank you
[email protected].
